Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Incoherent mesh problem.
5 REPLIES 5
arteom.kor
577 Views, 5 Replies
Hi! I am working on my diploma project (at Belarusian National Technic Univercity) at the moment, and for the last three weeks i have been struggling with incoherent mesh error. I linked all structure objects to gird in Revit, ran detailed correction to 5 mm module. I also used recomendations from previous posts, but still there are mistakes. May be more expirienced users in this forum can help because the time is running out i cannot run the analysis, obtain forces values and start reinforsment calculations.
The model is somewhat incomplete, becuase of some simplifications and because postponing final corrections till correct meshing obtain. What i do wrong?
 https://www.dropbox.com/s/h3gr87fm3vpjp0i/diploma.zip A link to a file in dropbox cloud is attached.
Thank you in advance.
5 REPLIES 5
Rafal.Gaweda
in reply to: arteom.kor
See below.
Correct model firts
Rafal Gaweda
arteom.kor
Is there so to speak auto model correction? I have used round up/down utility, panels spreadsheet correction macros, yet without success.
Rafal.Gaweda
HINT : If you want to correct Walls you habe to change them onto Panels first in Inspector
(This works on multiselection)
Rafal Gaweda
Tags (2)
Rafal.Gaweda
in reply to: Rafal.Gaweda
As far as I could : corrected model : http://we.tl/49rwBLZR04
Rafal Gaweda
arteom.kor
Thank you very much!
