Discussion Groups
Robot Structural Analysis
Active Contributor
STP_MS
Accepted Solution
Incoherent mesh on edges
415 Views, 2 Replies
03-01-2013 12:17 AM
Hi all
I'm designing a building and I'm experiencing a problem with Structure verification. Each time I run calculation, the program displays Incoherent mesh on edges error.
Thank you in advance.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Incoherent mesh on edges
03-01-2013 12:27 AM in reply to: STP_MS
Few hints:
- run model detailed correction to structural axes
- do not use regular mesh
If it does not help please send us the file.
Rafal Gaweda
Product Support
Rafal.Gaweda
03-01-2013 12:52 AM in reply to: Rafal.Gaweda
Possible correct meshing parameters:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Various-problems-on-mesh-generation/m-p/3764... - message 3 ; FE size - for your consideration.
Rafal Gaweda
