Hi all
I'm designing a building and I'm experiencing a problem with Structure verification. Each time I run calculation, the program displays Incoherent mesh on edges error.
Thank you in advance.
Solved by Rafal.Gaweda. Go to Solution.
Few hints:
- run model detailed correction to structural axes
- do not use regular mesh
If it does not help please send us the file.
Possible correct meshing parameters:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Various-problems-on-mesh-generation/m-p/3764... - message 3 ; FE size - for your consideration.
