hello, than I am calculating required reinforcement of RC panels an error appears:
INCOHERENT DATA OF RC PANEL.
In the reinforcement table there are some nodes with errors, but forces in these nodes are not maximal.
I tried to change the reinforcement parameters, but it does not help.
What should I do? Can I ignore those errors and go to provided reinforcement of RC panels?
Does the errors have any influences in final results of required reinforcement?
Any advice, please
You can check the values in the centers of the neighboring elements and use these values instead. Could you attach the model and indicate which panel to look at as well as what load cases you typed in ULS and SLS lists please? Thank you.
Please look at panel 1347. There are few nodes with error.
http://www.4shared.com/zip/YmfqtAXJba/VILNIUS_PANEL_1.html
Thank you
With the settings like this:
And my file : http://www.filemail.com/d/hfkmulrcxzalymo I do not see any problems.
BTW I strongly recommend to correct file to get rid of instabilities.
I do not understand, I just download your file and calculate it without any changes, and than I tried to calculate
panel No.1347 requied reinforcement the same error "INCOHERENT DATA FOR PANEL no. 1347" appears.
Maybe the problem is with may program version. I work with "Autodesk robot structural analysis professional 2013"
So, can I ignore it and provide reinforcement as in neighbors nodes, or should I do any correction in model??
Thank you
OK, but if there are any possibilities to avoid this type of errors or it is just something wrong with "Autodesk robot structural analysis professional"
