I´m studying a structure with inclined column so the wind load is much important.
However, I can´t select inclined panels to generate the automatic wind load. There are a way to apply the wind load or the projection of it without a manual calcul?
Solved by t.sautierr. Go to Solution.
Edu , da Audax??
de qq maneira ,tb sou do Rio.
Tá esquisito esses painéis das lajes aí atravessando as paredes.Voce modelou como shell(elementos finitos) ou cladding??
Pra selecionar fica mais facil se vc mandar aparecer o contôrno dos painéis (Display/panels/Panel contours).
Vc tá sabendo que essa geração automatica de carga de vento é de acôrdo com a norma francesa ,né?
Translating
It´s weird to see the slab panels cutting the wall panels. Did you model them as shell(finite elements) or as claddings??
To select a panel easily it´s better to turn on Panel contours on Display/Panels/Panel contours
I guess you already know that this wind load automatic generation is according to the French code.
Rafael Medeiros
Hi, yes I know that it´s the french norm that I´m using.
I can select the cladding but I can´t select it when I want to use the automatic wind load generation.
I calculated manualy the load´s wind and I try to apply it to my claddings but the distribution doesn´t work.
I would like apply the load in the global coordinate system, how can I do it?
File please.
Normally no problem to geenrate wind loads on inclined cladding as long as it is planar.
