My massage is adressed to Robot developers team. If Rafal/Artur could comment on this then it will be great. The idea is to improve robot automatic slab reinforcement. Its possible in Reinforcment pattern - Bars tab to pick diameter of reinforcement in X and Y direction for top and bottom layer. We can also pick spacing, define preferred reinforcement spacing. But none of this options is useble in reality. The only 1 way is to switch to manual option and define reinf. zones and bars by hand. It would be much more simplier and easier if we have an opportunity in the same bars window/tab to predefine something like "main mesh" for panel and for zones, where area is not enough Robot can add additional reinforcment. I hope you understood me. I hope its not so hard to implement.
Solved by Artur.Kosakowski. Go to Solution.
Hi
You can define reinforcement zones manually. Please find the attached files
@Jummybear wrote:My massage is adressed to Robot developers team. If Rafal/Artur could comment on this then it will be great. The idea is to improve robot automatic slab reinforcement. Its possible in Reinforcment pattern - Bars tab to pick diameter of reinforcement in X and Y direction for top and bottom layer. We can also pick spacing, define preferred reinforcement spacing. But none of this options is useble in reality. The only 1 way is to switch to manual option and define reinf. zones and bars by hand. It would be much more simplier and easier if we have an opportunity in the same bars window/tab to predefine something like "main mesh" for panel and for zones, where area is not enough Robot can add additional reinforcment. I hope you understood me. I hope its not so hard to implement.
Another thing is that RSAP does not put into consideration reinforcement layering. I don't know if RSAP takes into consideration "d" if we add multiple zones on the same place or it is just single layer with decreasing spacing to compensate?
You didnt understand me correctly. I dont have any problems or questions to manual reinforcement (to be honest, i have 1 about displaying/changing mesh types) and i wrote about it in the past in some tipoc but I get no positive feedback on it 🙂 I attached 1 jpg abput this issue. I want Robot to display zones with colors for mesh 16-200/200 for example and zones with mesh 16-200/200+additionally 20-400/400. But i cant define it in this way, because 20-400/400 will be separatly without taking into account mesh 16-200/200.
And what I am speaking about is on pic Robot2.jpg. I want to predefine some typical mesh for whole plate and want Robot to take it into account while generating reinforcment zones automatically. In those places, where its not enough let Robot generate reinfocment zone and add additional reinforcment to my predifened mesh. I hope ppl can understand me 😃
@Jummybear wrote:You didnt understand me correctly. I dont have any problems or questions to manual reinforcement (to be honest, i have 1 about displaying/changing mesh types) and i wrote about it in the past in some tipoc but I get no positive feedback on it 🙂 I attached 1 jpg abput this issue. I want Robot to display zones with colors for mesh 16-200/200 for example and zones with mesh 16-200/200+additionally 20-400/400. But i cant define it in this way, because 20-400/400 will be separatly without taking into account mesh 16-200/200.
I think RSAP does not do what you want it to do. You can,t make robot predefine those. you are going to change it yourself during manual meshing.. 😕
Added to the wish list for the next versions.
One more thing: on my pic Robot1.jpg in reinforcement map there are 2 diam, fi1 and fi2. In my opinion this option could work better, there are 1 thing to improve also. How it works now: i can pick diam1 and diam2 and a step. For example I choose diam 12 and diam 16 with step 200mm. I expect that i get both of them with step 200mm, but for Robot it means bar12 -200mm-bar16-200mm-bar12 and so on. So in reality we have bar12 and bar16 with step 400mm. It makes all of us happy if we could define 2 diameters with 2 steps (each step for each diameter). For example: bar12 with step 200 and bar16 with step 200 in one meter. Finally i want to get coloured picture of zones with:
1. mesh 12-200
2. mesh 12-200+16-200
3. mesh 12-200+20-200
and so on. Now its not posiible to it in that way. Thanks.
