Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Importing dwg in Robot - problem with ARCS
6 REPLIES 6
Mirko.Jurcevic
1590 Views, 6 Replies
Hi!
I am having a problem when I try to import this dwg file into Robot (as a dwg background).
I've tried with dxf, same thing.
The thing is that slab perimeter is made of arcs an they are not imported in Robot.
When I've turned them into polyline arcs (in AutoCAD), they appear but as single straight line.
I've manage to import it with "File > Open project..", but that's not what I've wanted.
Any suggestions?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
6 REPLIES 6
Rafal Gaweda
Thanks Rafal,
Yes, that's what I've already done..
But, I cannot import it via "File > Import > DXF and DWG Backgrounds..."
Mirko Jurcevic
Unfortunately you are right.
Rafal Gaweda
t.sautierr
in reply to: Mirko.Jurcevic
Actually you can if you do it in Cad :
convert pline in arc in pline, then divide it into x points and redraw a pline with this points, explode pline (maybe last step in not necessary)
In fact, it is what robot does with the menu rafal showed ... but you will be able to import directly ...
Now you need a routine in CAD 😛
t.sautierr
in reply to: t.sautierr
and as a back ground, as it is what you wanted ...
Mirko.Jurcevic
Yes, thank you Thomas, I thought of that too, but that's few more step that I simply didn't wanted to do.
Robot should do it automatically.
I hope it will be corrected in the next SP or at least in new version.
 But it stands as an option when I really want it as a background. 🙂
Mirko Jurcevic
