Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Import model from Revit to Robot have proplem
5 REPLIES 5
huynhhoangvt
400 Views, 5 Replies
I have problem when i imported model from revit to robot.It  was appeared at intersection between columns and beams.Please advise to me.
5 REPLIES 5
Rafal.Gaweda
in reply to: huynhhoangvt
Model is inaccurate. Correct it.
How do i assign wind load and now load in Robot according to Eurocode?
Calculate loads values according to Eurocode, apply them on structure.
Rafal Gaweda
huynhhoangvt
in reply to: Rafal.Gaweda
I calculated loads values according to Eurocode but also i  have not  knew how to apply it in robot.Could you help me? Thanks for advising.
Rafal.Gaweda
Use Nodal loads and\or Bar loads and\or Panel loads , like for any other load cases
Rafal Gaweda
huynhhoangvt
Thanks so much.Now i also have a problem. When i have imported model from revit to robot.The floor are not  lied on the top beams.So it is lied over the beams( picture 1).After that i turn off section shape of frane.It is ok.( picture 2). Some of picture show below.I really want the floor is correct with the beams is it effect to caculate frame?Please help me.!1.png3.png
Rafal.Gaweda
If you turn off section shape and offsets and bar line is displayed on panel edge -> model is correct
Rafal Gaweda
