I have problem when i imported model from revit to robot.It was appeared at intersection between columns and beams.Please advise to me.
How do i assign wind load and now load in Robot according to Eurocode?
Solved by Rafal.Gaweda. Go to Solution.
Model is inaccurate. Correct it.
Calculate loads values according to Eurocode, apply them on structure.
I calculated loads values according to Eurocode but also i have not knew how to apply it in robot.Could you help me? Thanks for advising.
Thanks so much.Now i also have a problem. When i have imported model from revit to robot.The floor are not lied on the top beams.So it is lied over the beams( picture 1).After that i turn off section shape of frane.It is ok.( picture 2). Some of picture show below.I really want the floor is correct with the beams is it effect to caculate frame?Please help me.!
