when i imort a DWG to RSA , i draw columns and walls on the background of DWG and i need to draw each column on the background .
isn't there another method to draw all columns with one click ? as SAFE !
that what i mean . I want to define all columns with one selection window .
How is this done in SAFE exactly? At the intersections of structural axes? Other way?
I left click -mouse and drag on all columns , it reads all columns and auto-define columns sections .
i don't define each column alone but all in one click-selection .
Hi
In STAAD the same thing exists. You define nodes. You use array (which causes nodes be repeated in direction). In this, there exist an option (link) which causes nodes (existing and added by array) to be linked by bars.
I hope the same thing could be done in ARSA (at least using API).
Rafael Medeiros
Robot Structural Analysis
