Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
I can not create a new material
7 REPLIES 7
Message 1 of 8
KestutisAblacinskas
746 Views, 7 Replies
In Job Preferences/Materials I select Modification. In Material Definition I create new material, press Add and Ok. If I again select Modification button I see new material. But if I close Job Preferences dialog and open it again - created new material is missing. How to save the new Materials? (Windows 8 64 and ARSAP 2013)
7 REPLIES 7
Message 2 of 8
Switch between layouts or restart robot
Rafal Gaweda
Message 3 of 8
if it were that simple, I do not would write here :). It is nothing unworthy answer.
Message 4 of 8
Try to clear cfgusr folder before next robot start.
Movie: http://screencast.com/t/STws1m09iJ
Rafal Gaweda
Message 5 of 8
I am facing the same problem on my PC (Windows 8 64 BIT RSAP 2013). I had this issue also on PC in my university (Windows 7 64 BIT RSAP 2013). I tried restarting program and deleting all files from mentioned folder. Doesn't work for me.
Message 6 of 8
Rafal.Gaweda
in reply to: Plasky1989
PLasky,
IN your case please check whether the file
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\rmat048.xml
 is changed after closing robot (and of course after creating new material before) or not.
If not, ask Administrator to check privilages you have to write \ modify this folder and \ or check firewalll \ antivirus settings.
Rafal Gaweda
Message 7 of 8
Rafal.Gaweda
in reply to: Rafal.Gaweda
BTW: have you pressed Add button as shown on the movie?
Rafal Gaweda
Message 8 of 8
I can not explain, but the problem is solved as follows: I create a new user with administrator rights, in his environment installs Autodesk Robot, go back to my  environment and enjoy my success ...
