Discussion Groups
Robot Structural Analysis
Valued Contributor
jo2ny
Re: How to support a structure in only one direction
02-27-2013 05:52 AM in reply to: Artur.Kosakowski
Very true and obvious :smileyhappy: duuh!
A combination between a case (that stand alone gives incorrect results) with other cases provides correct results, that whas my concern; but you cleared it.
( I could be a little bit nosey and ask who/why does this happen, but I shouldn't go offtopic, so i'll ask this later)
THANKS AGAIN for your anwsers, very helpfull.
Please use plain text.
Product Support
Artur.Kosakowski
02-27-2013 07:02 AM in reply to: jo2ny
If you mean why lateral load case does not converge then check it may happen that just overturns the model (all UZ+ supports are switched off as the model starts to rotate). In other words check where your neutral axis is located vs. the support arrangement.
Artur Kosakowski
Valued Contributor
jo2ny
02-27-2013 07:07 AM in reply to: Artur.Kosakowski
I fixed the convergence problem using a combination between these two suggestions: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nonlinear-analysis-Iteration/m-p/3385747/hig... http://forums.autodesk.com/t5/Autodesk-Robot-Structural/convergence/m-p/3469484/highlight/true#M5032 Now everything looks fine, the reactions are all positive or 0 for the UZ+ supports. Thanks, again for your support.
