Hi
At verification/analysis I get messages that there are isolated nodes. I am new to Robot and am finding it hard to detect and remove these nodes. When I click the warning they dont show on the screen and furthermore are not selected so that I can delete them. How can I resolve this problem ???
Solved by victorjusten. Go to Solution.
Open file in repair mode
Delete isolated nodes
Correct rigid link
Corrected file attached.
Thanks a lot !!!
I have some questions about this model that you sent to me. I saw that you made a fixed support on joint 6511 (a joint that i used as the master on rigid´s link to transfer the loads to the entire structure). I suppose that the fact of using this joint as the master does not mean it is connected to structure. If i go to "ANALYSIS / VERIFICATION " i receive an alert that there are isolated nodes on this model that you sent to me, but the software runs the calculation normally.
Thanks !!!
My mistake. Delete this support.
Hi Rafal !!!
I´ve tried to do what you told me, but when i go to Analysis / Verification and check the "ISOLATED NODES" and click "DELETE", the nodes don´t delete. I went to VIEW/ DISPLAY and check "DISPLAY ATTRIBUTES ONLY FOR SELECTED OBJECTS" but the isolated nodes don´t appear. How did you do to delete this isolated nodes in this model ?
In the model that you sent to me, i observe that the model have 1 isolated node (NODE 6511 - the master of the rigid link) but this model run the calculation normally.
Thanks a lot !
Victor
