Discussion Groups
Robot Structural Analysis
Active Contributor
antoine.carimalo
How to modify easily "linear on edge" loads ?
155 Views, 7 Replies
01-28-2013 10:50 PM
For usual loading types (uniform planar loads as exemple) I can modify easily loads parameters using the following tips :
1- Load table -> Table edition -> left clic on the "list" case corresponding to the load I want to modify
2- go to general view -> select new element to apply load by left clik with CTRL button pull on
But I cannot perform the same tips for the "linear load on edges" type
Regarding this type of load, I don't arrive to select only one edge of a pannel
For the moment I must delete all linear loads on edges an rebuild
Is there another enjoying solution ?
Please use plain text.
Product Support
Re: How to modify easily "linear on edge" loads ?
01-29-2013 12:28 AM in reply to: antoine.carimalo
You can type edge number in the List field additionally then press Tab or Enter to cofirm change
Rafal Gaweda
Active Contributor
antoine.carimalo
01-29-2013 12:47 AM in reply to: Rafal.Gaweda
Hi
What the command to asset the edge number in the list field ?
Do I need to type :
1
_
e
d
g
e
2
Or there is shortcut ?
If the list field contains many edges from many pannels, this tips makes sometimes mistakes.
If I modify one edge on a list, sometimes I found other loads on edges modified when I come back to the 3D view.
Do you know why?
Product Support
01-29-2013 01:05 AM in reply to: antoine.carimalo
Do I need to type :
1_edge(2)
Exactly, or in case of applying load to several edges of the same panel like that 1_edge(1 2 4)
Show me example.
Rafal Gaweda
Active Contributor
antoine.carimalo
01-29-2013 01:41 AM in reply to: Rafal.Gaweda
Ok thanks you,
maybe I maked something wrong because I built a new model an it works.
But it is not very fine modify loads by this way.
Is there a possibility to delete or change value of a linear on edges load by the 3D view as we can do for ather kind of loads?
Product Support
01-29-2013 02:14 AM in reply to: antoine.carimalo
Right hand mouse click on load symbol....
Rafal Gaweda
Active Contributor
antoine.carimalo
01-29-2013 07:06 AM in reply to: Rafal.Gaweda
Problem is when I modify load value with RMB on load, it changes the value for all edges included in the list field of te table.
Not very usefull and dangerous
Thank you
Product Support
01-29-2013 08:12 AM in reply to: antoine.carimalo
Thx for reporting.
I will check.
Rafal Gaweda
