How to modify easily "linear on edge" loads ?
7 REPLIES 7
Message 1 of 8
antoine.carimalo
387 Views, 7 Replies
For usual loading types (uniform planar loads as exemple) I can modify easily loads parameters using the following tips :
1- Load table -> Table edition -> left clic on the "list" case corresponding to the load I want to modify
2- go to general view -> select new element to apply load by left clik with CTRL button pull on
But I cannot perform the same tips for the "linear load on edges" type
Regarding this type of load, I don't arrive to select only one edge of a pannel
For the moment I must delete all linear loads on edges an rebuild
Is there another enjoying solution ?
7 REPLIES 7
Message 2 of 8
You can type edge number in the List field additionally then press Tab or Enter to cofirm change
Rafal Gaweda
Message 3 of 8
Hi
What the command to asset the edge number in the list field ?
Do I need to type :
1
_
e
d
g
e
2
Or there is shortcut ?
If the list field contains many edges from many pannels, this tips makes sometimes mistakes.
If I modify one edge on a list, sometimes I found other loads on edges modified when I come back to the 3D view.
Do you know why?
Message 4 of 8
Do I need to type :
1_edge(2)
Exactly, or in case of applying load to several edges of the same panel like that 1_edge(1 2 4)
Show me example.
Rafal Gaweda
Message 5 of 8
Ok thanks you,
maybe I maked something wrong because I built a new model an it works.
But it is not very fine modify loads by this way.
Is there a possibility to delete or change value of a linear on edges load by the 3D view as we can do for ather kind of loads?
Message 6 of 8
Right hand mouse click on load symbol....
Rafal Gaweda
Message 7 of 8
Problem is when I modify load value with RMB on load, it changes the value for all edges included in the list field of te table.
Not very usefull and dangerous
Thank you
Message 8 of 8
Thx for reporting.
I will check.
Rafal Gaweda
