Hi!
Please help me interpreting the moment results on the panel (slab).
I've attached two images: one with hand calculation of getting the maximum bending moment on the slab (DDM) and one with my robot model.
I simply don't know how to interpret the map or cut result of slab.
I've done lot of steel design using robot, but not much on panel design. However, I believe my model is correct.
I am currently trying to prove my office that robot can be used to design slab, but I failed to convince them because I didn't know how to interpret the result.
I believe the maximum bending moment must be at least similar to the one by hand calculation.
Please help me. Thank you!
Solved by Artur.Kosakowski. Go to Solution.
Pease check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/strip-method/m-p/4923878
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
No, the right topic. I wanted to know the answer to this post. However, have not quite found it in any of the attached 3 links.
