Artur,
in addition, I have a panel/shell and a brace in the same plane. When I mesh the shell, it takes the brace into the meshing. How can I mesh the panel/shell so it will ignore the brace?
Thanks in advance
Solved by Artur.Kosakowski. Go to Solution.
See the message 4 below.
