Discussion Groups
Robot Structural Analysis
Member
Hollow core slabs and seismic
266 Views, 7 Replies
02-13-2013 08:12 AM
can anyone tell me is it possible to do modal analysis and seismic calculation with hollow slabs in construction model?
Thank you very much.
Ivana
Please use plain text.
Product Support
Re: Hollow core slabs and seismic
02-13-2013 08:29 AM in reply to: Ivana1607
Yes, it can be calculated.
Rafal Gaweda
Member
02-13-2013 11:41 AM in reply to: Ivana1607
Thank you for your answer. I've already defined hollow slab in my model but during analysis error 902 appears. After that I changed the slab into homogeneous (just for check) and no errors showed, calculation was fine. I thought maybe self weight of hollow slab is not converted to masses?!
Product Support
02-14-2013 01:25 AM in reply to: Ivana1607
Error description :
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-8E8ED7A4-9A55-4F1F-8771-7E1A9CE...
902
Negative eigenvalue has been obtained
PLease send me model to check
Rafal Gaweda
Member
02-14-2013 06:15 AM in reply to: Rafal.Gaweda
Here is the model. (Original model is too big to send so I made a little example)
Thank you.
Ivana
Product Support
02-14-2013 06:39 AM in reply to: Ivana1607
Ivana,
Take a look below. You have defined wrong geometrical properoes of holes in holow slab.
Opening bottom edge is 2mm below slab bottom layer
ho/2 = 160 and hc=158 -> ho must be less or eq to 316
Rafal Gaweda
Product Support
02-14-2013 06:46 AM in reply to: Rafal.Gaweda
To help you checking : matrix values can not be negative
Rafal Gaweda
Member
02-14-2013 06:53 AM in reply to: Rafal.Gaweda
Yes, that was the problem. Thank you very much!!
Ivana
