I am trying this offset commnad, and everytime I see only the beam or column changing their positions.
What should I do if I want the beam to be where it is and instead the floor or panel moves up to the upper flange ?
Solved by Rafal.Gaweda. Go to Solution.
Not possible.
Offset works on bars only.
