I can not understand this message (see attached image).
What are you asking me? In addition, the beam does not verify VRD at 0.00 m!!?.
The foundation beam is constituted by a single element.
thanks
Solved by Artur.Kosakowski. Go to Solution.
This is the suggestion to switch on generation of reinforcement in the perpendicular direction too.
You can ignore this as caused by generation of the theoretical beam resistance diagram with reduction of capacity of main reinforcement along the anchorage length.
