Help file error?
6 REPLIES 6
742 Views, 6 Replies
Help file error?
Hi
Is this a typo?
link to help page:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-FB3C86D3-0E30-43A6-82D6-6C50F429FA0-600.htm
Both descriptions are the same.
Cheers,
6 REPLIES 6
Rafal.Gaweda
Thx for pointing this out
Rafal Gaweda
Artur.Kosakowski
The correct settings for both NR methods are shown on the attached picture.
Artur Kosakowski
SIX months have passed, and the error is still there....
Artur.Kosakowski
Patrick,
We do our best to introduce as many corrections and improvements as possible but please note: Not all identified issues are considered significant enough to address in their entirety; a proposed correction may create significant stability risks; some issues may be impossible to fix due to product architectural restraints or can be introduced in a specific time frame only. Thank you for your understanding in this matter.
For this particular situation the analysis dialog clearly indicates which method is being used. In addition the results for Full NR and  Modified NR method are the same provided the analysis converges so the selection of the check boxes should not cause any issue for a user.
Artur Kosakowski
in reply to: Artur.Kosakowski
I am afraid you will not convince me that not fixing just two sentences in the help for six months is justified. But I appreciate your explanation, it is certainly informative as to what pace of development can be expected in the future.
Pawel.Pulak
Fixed in the online help.
See:
http://help.autodesk.com/view/RSAPRO/2015/ENU/?gui​d=GUID-FB3C86D3-0E30-43A6-82D6-6C50F429FA0D
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
