Discussion Groups
Robot Structural Analysis
Help For Beginners
778 Views, 10 Replies
09-22-2012 04:44 AM
Hi Friends, I am a new user of Robot. I am finding too many problems here. I hope somebody can help.
1.When I want to draw a floor slab, if I draw differently (clockwise or anti-clockwise, starting from longer beam or shorter beam side) it shows different maps in stresses and moments. So what is the actual method? How should I draw?
2. There are too many options. Floor, Panel, Cladding ... Inside Floor there are Shell, Deck Slab (One way), ... If I want to draw a solid floor salb which one I should use? And when I should use the others?
3. How can I design T-Beams? I mean when I set code parameters, it says that T-Beam was considered, but doesn't show any reinforcement for flanges, only shows for webs.
4. Some times when designing required reinforcement in beams, it says that for certain  beam there is "insufficient capacity against shear". Why is it happening and how to solve it? (In the attachment beam no. 33 and 66)
5. In the attached file, I drew the edge columns aligning centers, without eccentricity. But as we know in reality, it will have to be constructed with 10 cm eccentricity (ei between the centers of col. no. 5 and 17). So how should I actually draw? If I draw with eccentricity, when designing the beams, it shows a message "Segmets of the length less than 10 cm have been removed, Transfer of the RC Element has been completed". What does this mean? Is this a problem? How to solve this?
Thanks In Advance.
Please use plain text.
Product Support
Re: Help For Beginners
09-24-2012 05:11 AM in reply to: toha_mh
Your choice. For results presentation please set correct  \ desired Direction
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-16AA1074-A4F2-4EAA-A456-86AF1F396341.htm
Rafal Gaweda
Product Support
09-24-2012 05:19 AM in reply to: toha_mh
Floor = slab :
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-316A5523-11CC-4857-B410-649A36B19A09.htm
in short : flat horizontal panel
If you want to use such panel \ floor in desing or get results use Shell.
http://docs.autodesk.com/RSA/2013/ENU/index.html?url=filesROBOT/GUID-13A7E8C9-AAB0-44CE-8C48-DC9BB38...
Rafal Gaweda
Product Support
09-24-2012 06:26 AM in reply to: toha_mh
Additional settings you have to use:
flange.jpg:
Rafal Gaweda
Product Support
09-24-2012 07:28 AM in reply to: toha_mh
Leave it as it is or use offsets.
But before take a look at these threads;
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Beam-offsets/m-p/3332921/highlight/true#M276...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Consequence-of-axis-position-offset-excentre...
Rafal Gaweda
Product Support
09-25-2012 07:04 AM in reply to: toha_mh
It is caused by torsion. Turn it off.
Developers will check tosion design.
Rafal Gaweda
Product Support
09-26-2012 05:30 AM in reply to: Rafal.Gaweda
Please check your \ Robot calculations (below). Let us know if there is any bug in Robot.
Rafal Gaweda
10-02-2012 03:51 AM in reply to: Rafal.Gaweda
Thnx a lot. Now it's clear to me.
But can't ROBOT design ribbed (hollow block slab)? I see there is a tab called othographic, but even when I use that, it doesn't show the ribs in the panel thickness, or doesn't design the ribs.
Product Support
Artur.Kosakowski
10-07-2012 01:59 AM in reply to: Rafal.Gaweda
@ RG_Adsk, how can I turn tortion off, please?
