Hi there, new to this program so need a little help if possible!
I am using ROBOT to import a DXF (Attached) however when I import it, some of the elements rotate and do not appear as they do in AutoCAD, help would be much appreciated?
The project is a bridge with a lattice effect truss above it, similar to Harthill Footbridge in the UK, deck stays in correct location but the steelwork all rotates!! HELPPPP!!
Chris
Solved by Rafal.Gaweda. Go to Solution.
