No matter what i do
incoherent mesh is always an error !?!?!?!?
redone revit
different options
tried Manually remeshing the project but nothing 😞 :'(
File please.
Why not to correct robot model instead of revit model?
Correct wall panels - the wall panels of one wall shoulbe be of the same length and should start / end in the same XY point.
If they are starting from slab edge they should start EXACTLY from slab edge
Wall panels should be located on top each other to create continous wall
So I guess you you correct them , delete all rigid links -> should be OK
The thing is i used copy to clipboard and pasted them aligned to all levels when using Revit
so i cant really see how this would help as i didn't create them individually
i ur opinion which file should i go with ?
Try to use Edit / Detailed Correct function in robot -> to Line or To PLane or to Sructural Axes
Good Luck, Have a nice weekend
