Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 14
Tmlk89
304 Views, 13 Replies
HELP PLZ
No matter what i do
incoherent mesh is always an error !?!?!?!?
redone revit
different options
tried Manually  remeshing the project  but nothing 😞 :'(
13 REPLIES 13
Message 2 of 14
tony.ridley
in reply to: Tmlk89
Message 3 of 14
Tmlk89
in reply to: tony.ridley
tried almost everything with no luck what so ever
Message 4 of 14
Rafal.Gaweda
in reply to: Tmlk89
File please.
Why not to correct robot model instead of revit model?
Rafal Gaweda
Message 5 of 14
Tmlk89
in reply to: Rafal.Gaweda
cuz i've done BOTH with no luck
i'll send u the robot file after correcting revit
and the one corrected in robot
Message 6 of 14
Tmlk89
Message 7 of 14
Tmlk89
Anyideas ?!
Message 8 of 14
Rafal.Gaweda
in reply to: Tmlk89
Correct wall panels - the wall panels of one wall shoulbe be of the same length and should start / end in the same XY point.
If they are starting from slab edge they should start EXACTLY from slab edge
Wall panels should be located on top each other to create continous wall
So I guess you you correct them , delete all rigid links -> should be OK
Rafal Gaweda
Message 9 of 14
Tmlk89
The thing is i used copy to clipboard and pasted them aligned to all levels when using Revit
so i cant really see how this would help as i didn't create them individually
i ur opinion which file should i go with ?
Message 10 of 14
Rafal.Gaweda
in reply to: Tmlk89
I had no time to look at revit model. Maybe on Monday.
Rafal Gaweda
Message 11 of 14
Tmlk89
i didnt send any revit file
only the robot ones
Message 12 of 14
Tmlk89
here's the thing our weekend is at thursday and friday
and i have to handle this with some auto-cad drawings tomorrow
so any help would be greatly appreciated
Message 13 of 14
Rafal.Gaweda
in reply to: Tmlk89
Try to use Edit / Detailed Correct function in robot -> to Line or To PLane or to Sructural Axes
Good Luck, Have a nice weekend
Rafal Gaweda
Message 14 of 14
Tmlk89
Already Done it with no luck
and thanks anyways
