Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Grid type in RC slab reinforcement design
1 REPLY 1
eiriknor
516 Views, 1 Reply
If I calculate provided reinforcement for a slab with grid type regular I get some errors saying that reinforcement can`t be created. But calculating with "considering characteristic points of slab geometry" everything works out fine. See the pictures.
In a kind of panic know as I calculated the reinforcement with grid type "considering characteristic points of slab geometry" and created the reinforcement drawing. Will the slab fall down?
1 REPLY 1
Artur.Kosakowski
in reply to: eiriknor
This option only governs automatic generation of reinforcement zones (areas of the same reinforcement distribution) and you can choose the way which is better suited for a given example. In this case the later seems to be a better choice Smiley Happy
Artur Kosakowski
