Dear members,
I would like to know if someone can share a excel sheet (VBA) to extracte the internal forces from all the bars of my structure. I just need the maximum internal force in the bar, not the values at the bottom or top of the bar (extremes nodes of the bar).
The internal forces that i need are: N, My,Mz;Vy;Vz (i dont need torsion).
I also want to have the possibility to choose all (or just one) the loads cases that i previously had defined in my structural model.
Thank you and regards,
fmp
Solved by Rafal.Gaweda. Go to Solution.
Yes, I have found many excel sheets, but none of them had all the the internal forces that i need (N,My,Mz;Vy;Vz) and also i don't know if there are new updated excel sheets (possible minor bugs corrected).
I have found a excel sheet that almost does what i want, the only problem is that some internal forces are missing, in this case i need N,My,Mz;Vy,Vz.
Dear RG_Adsk
I want create model in RSAP from excel
And Get Result In RSAP to Excel
please guide me how to do?
Does not need to learn VBA? or C #?
If you want to use Excel - use Excel VBA.
Yes Thaks you
I'd love to use VBA for this work
Modeling in RSAP from excel use VBA
Please guide for me
