Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Generating drawings for RC Container walls
4 REPLIES 4
gustavo_c_vasconcellos
682 Views, 4 Replies
Dear support,
I am trying to generate drawings for a RC Container and I am able to generate it for the slab but not for the walls. I do the calculations for required, provided ... I can see the results on the "Wall Reforcement" tab, but when I generate the drawing, nothing appears on the layout. Thanks Gustavo
4 REPLIES 4
Gustavo,
Could you send screen captures that show the panel (wall) on the model, provided reinforcement you generated and what you get on the drawing please? I hope that looking at them I will able to answer your question  - if not I will ask you for the model.
Artur Kosakowski
As requested, I am sending the screen pictures. Thanks, Gustavo
My assumption is that you hasn't set any drawing template (Analysis > Drawing Parameters). Please select one that is intended for walls as shown on the attached picture.
Artur Kosakowski
Easy like that !!!!
Smiley Very Happy
I was using slab template.
Gustavo
