Dear support,
I am trying to generate drawings for a RC Container and I am able to generate it for the slab but not for the walls. I do the calculations for required, provided ... I can see the results on the "Wall Reforcement" tab, but when I generate the drawing, nothing appears on the layout. Thanks Gustavo
Solved by gustavo_c_vasconcellos. Go to Solution.
Gustavo,
Could you send screen captures that show the panel (wall) on the model, provided reinforcement you generated and what you get on the drawing please? I hope that looking at them I will able to answer your question - if not I will ask you for the model.
As requested, I am sending the screen pictures. Thanks, Gustavo
My assumption is that you hasn't set any drawing template (Analysis > Drawing Parameters). Please select one that is intended for walls as shown on the attached picture.
