- Is there any possibility to generate the wind loads for multistory concrete buildings by (ROBOT ARSApor 2013) or not . if possible please help me by steps how can I generate it ?
- In the attached capture form (CBSpor 2013 ) , I have noted that there is no importance factor. Pls explain ?
Refaat
Solved by Refaat. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
according to ASCE7-05?
This code is not imlpemented for 3D generator.
How can i define these parameters ?
these method gives the wind force on each story ?
