Discussion Groups
Robot Structural Analysis
Member
Generate EC wind loads by API
318 Views, 5 Replies
09-11-2012 01:02 AM
I am trying to understand how to generate Eurocodes wind loads by API.
This how I proceed:
First I configure the project prefs
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "NF-EN 1991-1-3/4/NA:2007/2008")
Then I generate the loads
        Dim SWCodeParams As RobotSWCodeECParams
        Dim SWCombEngine As RobotSnowWindEngine
        SWCombEngine = str.Cases.SnowWindEngine
        SWCodeParams = SWCombEngine.CodeParams
        SWCodeParams.StructureAge = 2
        SWCombEngine.Params.TotalDepth = 15
        SWCombEngine.Params.BaySpacing = 5
        SWCombEngine.Generate()
I don't see how to configure SWCombEngine with SWCodeParams.
Your help would be very appreciated. Thanks in advance.
Francois
Please use plain text.
Product Support
Re: Generate EC wind loads by API
09-12-2012 01:36 AM in reply to: fpiedebois
Code names are listed in this file:
"c:\Users\All Users\Autodesk\Structural\Common Data\2013\Data\Other\norms.xls"
so correct line should be like that:
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_SNOW_WIND_LOADS, "EC1 - French NAD")
Rafal Gaweda
Member
09-12-2012 01:51 AM in reply to: fpiedebois
Ok for that but it does not change anything.
I would like to change programmatically the parameters of eurocodes wind and snow loads genereation.
If I do
        SWCombEngine.CodeParams.WindCd = 1.5
        MsgBox("WindCd " + SWCombEngine.CodeParams.WindCd.ToString)
WindCd value still remains unchanged to 1.
Maybe this cannot be done by API.
Francois
Product Support
09-12-2012 02:10 AM in reply to: fpiedebois
Unfortunately you are right. Due to bug in API you can not set Params, Codeparams for SW generator.
You can only get them. I will register it for correction.
Rafal Gaweda
Member
09-12-2012 02:15 AM in reply to: Rafal.Gaweda
Great, I was struggling since 2 days on it to find a solution. Do you think it can be implemented in the next update of Robot?
Again thanks for your help, I think I will have more questions in the future.
Francois
Product Support
09-12-2012 02:18 AM in reply to: fpiedebois
workaround : RobApp.Project.Structure.Cases.SnowWindEngine.ShowParamsDlg()
then enter these values manually in the window
Rafal Gaweda
