Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
General steel connections
12 REPLIES 12
Message 1 of 13
TorgrimO
793 Views, 12 Replies
I am designing a steel structure, see attachment. I want to design the connections marked with red, but with the tube truss connection, I have to define 2 diagonals, including chord and post. Is there a way to define the connections in mention? It is RHS-RHS and RHS-HEA connections.
12 REPLIES 12
Message 2 of 13
Artur.Kosakowski
in reply to: TorgrimO
That should be possible.
Artur Kosakowski
Message 3 of 13
TorgrimO
in reply to: Artur.Kosakowski
How did you create that connection? If I try to create connection from selected bars i get an error.
Message 4 of 13
Artur.Kosakowski
The connection algorithm has got some restriction regarding supported section types and their orientation in the space. I'll try to check what the possible reason can be if you attach the file.
Artur Kosakowski
Message 5 of 13
TorgrimO
PM sent
Message 6 of 13
Artur.Kosakowski
The HEA section (chord) has to be 'vertical' with posts being connected to the flange rather than the web.
Artur Kosakowski
Message 7 of 13
TorgrimO
So if I use RHS instead of HEA columns, I will be able to design all the connections in Robot?
Message 8 of 13
Artur.Kosakowski
I'm not sure if all but some should be possible. Mind that you would need to move the support (slightly up or down) from the connection node to create it.
Artur Kosakowski
Message 9 of 13
TorgrimO
Does the gusset plate connection support anyting else than U or L profiles?
Message 10 of 13
Artur.Kosakowski
No, it dos not. What kind of profiles would you like to use?
Artur Kosakowski
Message 11 of 13
TorgrimO
I would like an RHS with a plate slotted into it which then is bolted to a gusset plate.
Message 12 of 13
Artur.Kosakowski
I have added this request to the wish list.
Artur Kosakowski
Message 13 of 13
Great Idea, of course. 🙂
But I think it should be better if you will digonally cut the eadges.
I hope it will gives you a nice and reliable design. 🙂
Thanks!
steelandsite
