My belief: This does not add to the confidence people have in a software dimensioning structures that will contain many hundreds of people.
Solved by Artur.Kosakowski. Go to Solution.
Solved by t.sautierr. Go to Solution.
Sure.
I will also adopt your attitude towards bugs, when coding our own software or a clients.
We will investigate this situation which is just incorrect estimation (display) of time needed for finishing generation of simplified code combinations (the combinations themselves are generated). Once generated they can be converted into manual combination with no further need for their generation (assuming this is the final version of the model). Otherwise you may use full generation of code combinations instead.
Same thing for me.
Don't think it induces any problem with calcs that's why I find this funny, if we were talking abourt 110% fo resistance ratio, I'd had a different reaction 😉
