Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Further development
2 REPLIES 2
faisal.aaouatif
245 Views, 2 Replies
Further development
Hi everyone
Would we expect that there will be some enhancement in reinforcement modules especially for concrete beams.
01.There are small but annoying things that I believe do sent need a lot of developing. .. For example :
The working of the object inspector should be reviewed by introducing a sorting function for elements (for the current version ,even if these elements are sorted manually for a given floor,if we are working on another floor and when going back to the first one , the elements are no longer sorted as done before even if the file was saved)
02.for beams sections or elevation definition ,after entering a first value ,let say for example the width ,by press the tab key the focus goes on another button other than the one that should be (height control button ); witch forces the user to use mouse click...
Please make a little effort in this direction
thank you
2 REPLIES 2
Thanks for reporting.
We will check what we can do.
Rafal Gaweda
Ok thank you.
Hope to see it he very next version ...
