Hey!.
When i cross the box for UX,UY, UZ, RX, RY and RZ i know that the spring stiffnes is not infinity but have a value. What are there values. this is for Node boundry contitions and linear boudrty conditions..
To define an elastic support you should type values of elasticity rather than mark the given check box as shown below:
There's no default value but you can use estimate it using the tool described here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Elastic-ground-bar-definition/td-p/3760644
