I get following message when calculating a foundation: "Condition not met for: Foundation punching", and then no reinforcement is calculated. I guess it shouldn`t be a problem for Robot to calculate the required reinforcement for punching in the same way it does for punching at slabs? Attached is the file.
In the same file I had to lock the dimensions or else I also got got sliding of the foundation, shouldn`t also that be fixed by Robot when Robot tries to opimize the foundation dimensions?
Solved by Rafal.Gaweda. Go to Solution.
That`s okay, but I don`t want the foundation to be 1,1 meter thick, then I`ll guess I get a phone from the contractor.
I think it may be just enough to switch off this verification and do it later by hand
