Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Forces in a slab acting like a stiff element
3 REPLIES 3
eiriknor
552 Views, 3 Replies
I have a horisontal floor bulid up by hollow core elements. This floor shall transfer the horizontal forces caused by wind and earthquake from the floor and to the stabilizing walls. But to desing the proper amount of reinforcement connecting the hollow core elements I need to know the moment an shear forces in the floor as if it was a beam. I this possible in Robot, I have looked at the results map and the Nxy and Nyy, but this isn`t giving me any results that I know how to use. I made a simple test-file (attached) and some pictures to show what I mean.
3 REPLIES 3
Artur.Kosakowski
in reply to: eiriknor
Try to use panel cuts. Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Strange-results-in-moment-strip/td-p/4775885 (message 14)
http://forums.autodesk.com/t5/Robot-Structural-Analysis/mat-foundation/m-p/3714038
Artur Kosakowski
eiriknor
in reply to: Artur.Kosakowski
OK, I`ll give it a try in the weekend.
Med vennlig hilsen
________________________________
Eirik Nordvik
Sivilingeni?r konstruksjonsteknikk
Byggeteknikk
Telefon
Mobil +47 90911657
Eirik.Nordvik@sweco.no
Sweco Norge AS
Bomveien 13
NO-7725 Steinkjer
Telefonnummer +47 74 160750
www.sweco.no
[cid:image001.jpg@01CF80C1.DD0094C0]
Please consider the environment before printing this e-mail.
Artur.Kosakowski
Mind that you can get the values of in plane bending  for panels directly.
Artur Kosakowski
