I have a horisontal floor bulid up by hollow core elements. This floor shall transfer the horizontal forces caused by wind and earthquake from the floor and to the stabilizing walls. But to desing the proper amount of reinforcement connecting the hollow core elements I need to know the moment an shear forces in the floor as if it was a beam. I this possible in Robot, I have looked at the results map and the Nxy and Nyy, but this isn`t giving me any results that I know how to use. I made a simple test-file (attached) and some pictures to show what I mean.
Solved by Artur.Kosakowski. Go to Solution.
Try to use panel cuts. Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Strange-results-in-moment-strip/td-p/4775885 (message 14)
http://forums.autodesk.com/t5/Robot-Structural-Analysis/mat-foundation/m-p/3714038
Mind that you can get the values of in plane bending for panels directly.
