Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
612 Views, 6 Replies
Forces in Walls
Hello!
I am modelling a structure in 3D and would like to check the forces in the core walls. Normally, you can simply look at the reactions, but I am supporting the walls on a raft foundation. Is there a way of checking the load under the wall being transmitted to the raft?
David
Tags (1)
6 REPLIES 6
Artur.Kosakowski
Try to look at the reduced results for panels or panel cuts.
Artur Kosakowski
in reply to: Artur.Kosakowski
Ok, thanks.
Not sure how you can extract the axial force below the wall though?
Artur.Kosakowski
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-3936FDA3-5DFD-4F31-B16A-F0208A451282.htm
Artur Kosakowski
Thanks Artur,
I can get the tabulated reduced results for the panels, but is there a way to display these grapically so I know where the different values correspond to?
Artur.Kosakowski
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Redused-results-for-panels-vs-Core-walls/m-p... (message 10). Use Panel cuts - reduced forces.
Artur Kosakowski
Artur.Kosakowski
Just to make sure I answered the right question: if by the axial force you mean the vertical one then in a wall then it is NRx. If you mean the axial in the wall foundation (horizontal along the the wall) then it is TRy.
Artur Kosakowski
