Footfall analysis_ can base acceleration be set manually?
1 REPLY 1
649 Views, 1 Reply
In footfall analysis, can base acceleration be custom set to give more flexibility?
1 REPLY 1
Pawel.Pulak
No, base acceleration is set only according to available codes, i.e. Concrete Centre (2006), SCI P354 Design of Floors for Vibration and AISC DG11: Floor Vibrations due to Human Activity.
But in case of SCI P354 and AISC DG11 base acceleration is a constant value and response factor is proportional to 1/base acceleration so it is very easy to convert it to different base acceleration value.
In case of Concrete Centre (2006) Design Guide it is more sophisticated because in case of resonant response the base acceleration is a function composed of 3 different branches for 4 Hz < fh < 8 Hz and moreover the overall response factor is calculated as SRSS of response factors for harmonics. But in this case it is possible to use detailed results for harmonics from Diagrams of Footfall analysis in RSA - see the attached screen capture. This data can be output to for instance MS Excel to be processed using arbitrary base accelerations.
If this post answer your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Best regards,
Pawel Pulak
Technical Account Specialist
