Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Footfall Analysis - Increment Number
5 REPLIES 5
538 Views, 5 Replies
When you run a footfall analysis, what is the increment number?  What does it refer to?  Basically, the footfall analysis runs PAINFULLY SLOW.  Strange thing is, even if I choose to only excite ONE node, the increment number does not change.  Limiting walking frequency, number footsteps etc does not change the increment.
I really need to speed up the analysis but am unsure how to proceed.
Robot 2011, SP4
6GB RAM, E8500 CPU@3.16GHz
5 REPLIES 5
Rafal.Gaweda
UNfortunatelly user is not able to control number of steps \ increments in footfall analysis. It is done automatically by program.
Rafal Gaweda
in reply to: Rafal.Gaweda
Rafal, thanks.  So what is your suggestion to avoid a 45 hour long analysis?
Rafal.Gaweda
If you do not mind please send us your model to check.
Rafal Gaweda
Rafal,
My model has a Hollowcore slab in it.
For my original footfall analysis run, I set the hollowcore to disregard stiffness in the transverse direction.
This run gave me 2117 iterations
Today, I turned off the disregard stiffness checkbox, and re-run the analysis.  Now I only have 100 iterations, and the analysis only takes a couple of minutes.  Can you please explain why there is such a large discrepancy in the calculation method.
Regards.
Rafal.Gaweda
Tony,
Without looking at model - number of modes?
I can see you have subscription so if you want to check this model by my please please create Service Rerquest via subscription center or if you are from GHD I can contact you.
Rafal Gaweda
