Discussion Groups
Robot Structural Analysis
Active Contributor
mjoflor
Fondation Beam
190 Views, 4 Replies
02-19-2014 07:16 AM
Hi , wheni modelling a fundation beam, it is necessary keep the support  in the columns or had to delete it????
Please use plain text.
Product Support
Artur.Kosakowski
Re: Fondation Beam
02-19-2014 09:50 AM in reply to: mjoflor
I'm not sure if I understand you correctly. If you think about a model then you should remove vertical supports at bottoms of columns if they 'stand' on the ground beam (elastic soil applied). For the RC design module the difference will be in the arrangement of stirrups as shown on the attached picture.
Artur Kosakowski
Active Contributor
mjoflor
Re: Fondation Beam
02-19-2014 01:10 PM in reply to: Artur.Kosakowski
ok but if i delete the supports and let only de foundation beam with the elastic soil applied ,and made a verificacion appears a warning "no support" ????????
Product Support
Artur.Kosakowski
Re: Fondation Beam
02-20-2014 12:25 AM in reply to: mjoflor
Indeed as the elastic soil definition is not a support type object the verification gives such message however knowing that you have supported a model correctly (mind the horizontal direction as well) you can ignore it.
Artur Kosakowski
Active Contributor
mjoflor
Re: Fondation Beam
02-20-2014 06:17 AM in reply to: Artur.Kosakowski
Ok thanks for your help
