Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Floors - span direction
4 REPLIES 4
AlexDT
3883 Views, 4 Replies
Hey,
I've got a floor which needs to span only in 1 direction.
I did a little test (used a hollow slab) and I get it to span in a direction, but I cant control the direction it is spanning in!
What else do I need to do?
The floor is carried by 4 concrete beams under every flooredge.
4 REPLIES 4
Romanich
in reply to: AlexDT
Try to use Linear releases from menu Geometry > Additional Attributes.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
in reply to: AlexDT
You should define the directions of the slab main span and load distribution in the same way. As the one way load distribution follows the local X of the panel (I know that everybody reads help Smiley Happy)
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-F57A58F9-81AA-4410-84EA-6BFFD83D115-214.htm
then you should define the ortho thickness in the same way (automatic direction stands for local X of the panel as well).
Artur Kosakowski
AlexDT
in reply to: Artur.Kosakowski
Thanks Romanich, but it didnt seem te make a difference.
Artur, I changed the local x axis. That seems to turn it.
The wiki is a lot of text and I got little time. I did got to that page, but I didnt get out of it how I could change this axis and that I had to change it.
So sorry if I keep asking things that should be obvious!
Artur.Kosakowski
in reply to: AlexDT
The things seems to be obvious when you already know them Smiley Happy Please feel free to ask all sort of questions you may have - this is what the forum is all about anyway. I'm glad that I managed to help.
Artur Kosakowski
