Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Floor vs Wall shell element and restrained beams
18 REPLIES 18
Message 1 of 19
byron86
1137 Views, 18 Replies
Hi I am checking a previous colleagues model and am noticing some things that I would appreciate some assitance with.
It is a big model and I will upload it if required but hopefully I can get by without doing so.
The model is for the design of a sliding table and crane mat on a barge.  All shell elements are modelled as a floor, steel, 300W.  Is there a difference between a wall and a floor panel?
Second question, I have noticed that for the barge itself below deck, it consists of angle beams.  There is no connections in the model but rather there are restraints put at the end of the angle beams.  How adequate is this.
Thanks for the help
18 REPLIES 18
Message 2 of 19
Rafal.Gaweda
in reply to: byron86
Wall - vertical, floor - horizontal
Panel - every orientation
Screen shot please.
Rafal Gaweda
Message 3 of 19
byron86
in reply to: Rafal.Gaweda
Firstly with regards to above.  So the structure type is panel therefore the orientation is okay, the material type is steel so obviously there is no reinforcement.  Im just confused with as to why it would show reinforcement type?
Message 4 of 19
byron86
For the second question, these angle beams are provided with this type of restraint throughtout.
Message 5 of 19
Rafal.Gaweda
Reinforcement Type is an independent properly and you can assigned or not to any panel with any material.But It can be only used for RC design for panels with concrete materials.
You may set "None" (N/A) on such panels.
Rafal Gaweda
Message 6 of 19
Rafal.Gaweda
And looking at screen shot I am confused
By restrain you mean phisical connection with wall and or columns or bar type for design (I guess steel) as marked on screen shot?
In case of further conversation please send us model or at least part of model with these pieces.
Rafal Gaweda
Message 7 of 19
byron86
As seen above currently there is a bar type with the buckling member length adjusted.  It appears my colleague wouldve done this to model fixity without modelling a phyiscal connection to the wall ?
If u still confused ill upload it.
Thanks again
Message 8 of 19
Rafal.Gaweda
If mesh nodes are generated along bar (unfortunately nodes are hidden by section shapes on your screen shot so I do not know it they are there or not) it means bar is connected with meshed panel.
Run Model Generation and then turn on display of "Numbers of calculation elements"- if there are blue numbers displayed on bars it means such bars are connected in some nodes with other bars or meshes
If you mean something else please send me model / part of model
Rafal Gaweda
Message 9 of 19
byron86
Ah okay,  I am in the process of uploading the model.  It still is in a messy state and will have to still solve some errors.
Will let you know when its done
Message 10 of 19
byron86
Message 11 of 19
Rafal.Gaweda
I need rtd file, not rt_.
Rafal Gaweda
Message 12 of 19
byron86
apologies, the internet is quite slow. I reduced the size of the file by deleting the loads
Message 13 of 19
byron86
Message 14 of 19
Rafal.Gaweda
Hint : it is much easier to navigate in model having global Z axis as height direction
I think everything is correct, beam is connected to wall (see blue numbers) so no buckling and lateral buckling defined in member type definition.
I am not sure if SLS check for such beam is required (activated in member type definition) because beam is connected to wall, but your choice.
Rafal Gaweda
Message 15 of 19
byron86
great thanks. Rafal, so connecting nodes regardless of type panel-bar, volumetric-bar, bar on bar; pif theres a node between them then the two elements are considered fixed unless the degrees of freedom are altered?
Message 16 of 19
Rafal.Gaweda
In case of solids-bars such connection is pinned because solid FEs have only 3 dof.
Rafal Gaweda
Message 17 of 19
byron86
Ah k thanks Rafal, appreciate the advice.   I still have some geometry changes to make and some loading but I might need some help with regards to the meshing.  I managed to get most of the errors away but continuosly get an instability type 2 or 3 error.
Secondly, is it recommened to use Robot up to 2 decimal places ?
Message 18 of 19
Rafal.Gaweda
File needed to check.
Programs operates on 15 digits, 2 after comma are displayed as a  default, you may display 9 if you want.
Rafal Gaweda
Message 19 of 19
byron86
Ah, lots of eureka moments here.  Thanks the hints are very helpful.
I have uploaded the file here
http://www.4shared.com/zip/d5hA8Dlvce/Barge.html
Most of the recommended settings for meshing I have used. Both in the job preferences and in the meshing options.
Thanks again
