Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Floor loads on supporting beams
4 REPLIES 4
stroxy
721 Views, 4 Replies
Hi
Is it possible to display
1.  the reactions from floors on their supporting beams.
Or
2.  the loading applied to a beam from the floor being supported
4 REPLIES 4
Artur.Kosakowski
in reply to: stroxy
Only if you replace them with (elastic) supports.
Only if you use cladding load distribution
Artur Kosakowski
stroxy
in reply to: stroxy
Add to wishlist??  It would be great if it was oncorporated in the calculation note for the beam!!
Artur.Kosakowski
in reply to: stroxy
This is the kind of analysis CBS uses for its 1st calculation method. The 'deflection' of  a beam in Robot being FEM type program (assuming you mesh panels rather than use claddings) depends on the overall stiffness of the structure rather than on a load distribution. This would require 'calculations' of loads based on actual deformation of  a beam.
Artur Kosakowski
Wrong:
You can overcome this by integrating supporting beam Fz force diagram:
Fz'(x) = -q(x)
q(x) = -∫Fz(x)dx
but it's too complicated for normal work.
Correct:
You can overcome this by derivating supporting beam Fz force diagram:
Fz'(x) = -q(x)
Fz(x) = -∫q(x)dx
I'm sorry, typo. Smiley Very Happy
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
