Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Floor Slab won't mesh
1 REPLY 1
1744 Views, 1 Reply
I've defined a floor slab as a rigid diaphragm which is supported on walls and columns. The walls will mesh but the floor slab will not. I've tried using the generate local mesh function, define the floor as a shell or a flexible diaphragm but nothing seems to work.
Any Ideas?
Tags (4)
1 REPLY 1
Artur.Kosakowski
Please check if you have the right panel calculation model assigned to the floor. Otherwise attach the file and indicate the panel to mesh.
Artur Kosakowski
