I've defined a floor slab as a rigid diaphragm which is supported on walls and columns. The walls will mesh but the floor slab will not. I've tried using the generate local mesh function, define the floor as a shell or a flexible diaphragm but nothing seems to work.
Any Ideas?
Solved by Artur.Kosakowski. Go to Solution.
Please check if you have the right panel calculation model assigned to the floor. Otherwise attach the file and indicate the panel to mesh.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
