I would really like to to be able to calculate a fixed steel column base connection with offset. Is that at all possible? There is a greyed out text box for offset, see below:
Solved by Artur.Kosakowski. Go to Solution.
Available only for the pinned column base according to French CM66.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
