Ferraillage d'une poutre courbé?
3 REPLIES 3
mohamedx61
1164 Views, 3 Replies
Bonsoir a tous. je voudrai savoir pour le ferraillage d'une poutre courbé comme le montre la figure en dessous:
es-que RobotSA peut la ferrailler ou pas et comme le faire dans le cas ou il ne peut pas? Merci
3 REPLIES 3
For bent beams you should use the RC Members Required Reinforcement module. Such beams are currently not supported in the RC Beam Reinforcement module.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
mais pourquoi nous n'avons pas se probleme losque nous exportons une poutre courbe a partir de cbs?
I think we are discussing two different situations:
- definition of  a curved beam in a model of a structure which can be done as chain of small straight elements forming a arch
- calculations of provided reinforcement in the RCA Beam design module which is currently not supported in Robot
Artur Kosakowski
