Hello
Can someone look at the linked model and see if they can do anything in it.
I have been working on this model for a day or two and this afternoon it suddenly became unresponsive, so much so that I think I am going to have to start again from scratch as I cannot do anything once it is loaded up.
I am wandering if I have too many panels and too many nodes for my laptop to handle.
I have:
223,753 nodes so far and I haven't finished meshing yet
about 3400 panels (mix of walls and slabs)
My laptop has the following specs:
CPU: Core i7 3840QM @ 2.80 GHz
RAM: 16GB
GPU: NVIDIA Quadro K2000M
20cm mesh on such huge model? I think 0,5-1m enough
I hope you have good reason to split every wall and slab for so many panels.
NOTE: every laptop of the same parameters as desktop computer is less efficient
Thanks for the reply.
Any chance you could delete my mesh and re-upload the model somewhere for me so I can still use it? That would be really be appreciated.
Just out of interest, do you have any ideas why Robot slows to a crawl with this model. I have done similar sized models with lots of panels and nodes in other software which perform much better when displaying the mesh.
223,753 nodes
Much better performance in Robot 2014. Try it , even in trial mode.
Ok,
So what has changed in 2014 that makes it much better?
I have noticed that Robot doesn't seem to make use of more than 2-3 cores on my Laptop. Have you guys improved the multithreading?
Robot, graphical performance....
Truly saying by mistake, it opened your file in 2014 yesterday that's why I did not see your problem. Now I am opening it in 2013........them same as on your side.
It should use 1 core during work except :http://forums.autodesk.com/t5/Robot-Structural-Analysis/Robot-on-2-or-more-processor-workstation/m-p...
Thankyou for the explanations.
Intterestingly, I opened the model again this morning and it seems to be working ok now!
So I am going to use a larger mesh and reduce the number of panels.
I will also get onto our IT dept and chase up the Robot 2014 install.
Many thanks for your help.
Please let me know, when you finish model , final number of nodes \ FEs and number of panels.
